NI TestStand
I.e. entire BT address wont print on report
Hello
I am currently struggling with having the called on commands printed onto the UUT report in a one-liner. I can get them printed on the report separate, using several of the CSP String Value Test functions, but would like to add them all together into one long string. I currently do not know how to concentrate the strings. Pleas see attached picture.
Thanks in advance, BR Andedam!
(2,027 Views)
Accepted by topic author Andedam
Are you able to post your sequence?
(2,008 Views)
Thanks, I have attached my sequence
BR Andedam
(2,001 Views)
I must confess I am still not sure what you are trying to do.  Please see the attached.  I have changed your four Tests to Actions and have added a String Value test afterwards.  I have configured the Data Source of the new test to the concatenated results strings from the 4 Actions.
(1,933 Views)
Hello, first thanks for the reply, although please ignore this post. I have posted a new more detailed post regarding the problem;
https://forums.ni.com/t5/NI-TestStand/Returning-only-final-string-of-SubSequence/td-p/4070330
Thanks!
(1,924 Views)
