NI TestStand
I'm using TestStand/Labview/SQL to do a query. Can you use a variable name in SQL instead of quotes around a value?
I'm using TestStand 2.0/Labview 6i with SQL open statement to do a query. Can you use a variable name with the SQL statement instead of quotes around a value? See example below.
SELECT * FROM STEP_COMMANDS WHERE STEP_COMMANDS.SPEC_NUMBER = '4.5'
I would like to use a variable instead of '4.5'. SPEC_NUMBER is a string type.
SELECT * FROM STEP_COMMANDS WHERE STEP_COMMANDS.SPEC_NUMBER = 'SPEC_NUMBER'
(3,058 Views)
You can use a variable with the right syntax. For example, in the SQL Statement window, use:
"SELECT * FROM STEP_COMMANDS WHERE STEP_COMMANDS.SPEC_NUMBER = '" + Locals.SPEC_NUMBER +'"
At run-time, the expression will be evaluated.
(3,058 Views)
