NI TestStand
I need to create a new custom types pallet for a separate project
I would like to create a new types pallet for a new project say project #2.  I currently have an existing project say project #1 that has its own custom step types.  I try to clear out the types pallet for project #2 so that I can start fresh but it will also clear out the type pallet for project #1.  How can I create a seperate MyTypes.ini for project #2?  Is it possible?
(4,150 Views)
Hi BCH63,
 There are some issues with creating multiple MyTypes.ini files since two concurring files with create a Type Conflict. Is there something unique in your application that requires multiple ini files since you can create multiple custom steps and actions in a single ini file?
I’ve also attached a white paper on an overview of Types in TestStand that explains Type Conflicts with INI files.
http://www.ni.com/white-paper/7060/en/#toc2
Ali S.
Applications Engineering
Ali S.
(4,118 Views)
Thanks for the response.  Yes, we could add a new layer to the types menu for this new project.  I was hoping I could tell TestStand where to find mytypes.ini.  That way I could have a project specific mytypes.  I'm not sure if it is possible to define where TestStand finds its global configuration files.
(4,112 Views)
Maybe there is another solution on handling type pallete files: Do NOT use them.
Just read discussion on this thread
http://forums.ni.com/t5/NI-TestStand/type-file-managment-with-source-code-control/td-p/2567099/highl...
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,091 Views)
