NI TestStand
I want my Test Sockets will run in loop
I want my Test Sockets will run in loop. I use BatchModel, sequential batch mode.
Now it works so:
process setup
main sequence of Socket 1...
main sequence of Socket 2...
main sequence of Socket N...
process cleanup
I want to do so:
process setup
loop 1
loop 2
loop N
process cleanup
How can I do it ?
(3,120 Views)
Marta,
Try using the PreUUTLoop and PostUUTLoop callbacks instead of ProcessSetup and ProcessCleanup.
Allen P.
NI
(3,111 Views)
Hi, Allen, thank you for your reply.
Now I want skip Batch dialog (UUTs dialog) and define myself number of Batch loops.
How I can to do it ?
(3,099 Views)
