NI TestStand
I want to generate multiple reports in Test Stand.
Hello oldmanXJ,
I don't really have any solution to your problem, but I read the posts and picked the phrase "spreadsheets are interpreted and run". Can you tell me how you do it?
We do something similar, we have XML files which describe the sequence of the tests, and we wrote our own process model which loads the xml file and calls the steps - where the steps are callback sequences in the process model.
regards
Madottati
Message 11 of 13
(1,082 Views)
Hi Madottati,
Could you clarify your question? Are you trying to load the xml file to call the sequence steps, or have you already gotten that working?
As a note, if this is a separate question, you'll probably be better off to post it as an entirely new forum post (it may get more traffic that way).
Christine B
Technical Support Engineer
Message 12 of 13
(1,070 Views)
Hi Juergen,
I am trying to do the same thing in the post, to generate multiple result in a single pass sequence. Could you clarify your idea more? An example is appreciate if it's possible.
Best,
Zijun
Message 13 of 13
(919 Views)
