NI TestStand
IE stuck
I have problem with opening XML format of report from teststand 2016 via IE (v11.678.17763.0), win10.
It open normaly, but after 3s, the page stucked and I have to restart explorer. For opening reports without teststand on computer, I copied file TR5_horizontal (and others) to path (C:\Program Files (x86)\National Instruments\TestStand 2016\Components\Models\TestStandModels\ATML\StyleSheets).
Do you have any ideas, why the reports stucking during viewing?
(2,056 Views)
I would check the stylesheet path in the raw XML file.  (This is in the first line of the XML after href="....)  Hopefully, the stylesheet in that path matches what you have in the computer.
It sounds like you're using a standard stylesheet, but if you've made changes to the stylesheet, that's another area I would look at.
Also, if your XML file is large (say, 20MB or more), there may be issues displaying in IE just because of memory.
(1,998 Views)
