NI TestStand
IF condition doesn't seem to be working
Hi guys
I don't understand why my IF statement is not working. From the function I declare the variable "Word0 = Step.Result.String"
Which yields "CAFE" in HEX
I then use an IF statement to check the first two HEX of the Word0;
Why is my IF statement returning false? As far as I understand, the syntax yields "no errors" and should check the Word0 for the First Two letters, to see if the word has 'CA' in the beginning, which it does
If Statement should yield "true"
BR Andedam. Really hope some1 can enlighten me
(1,740 Views)
The statement as is written above is correct so, the error should be somewhere else.I have isolated it in this example and it works for me.
Can you confirm that works for you as well?
(1,716 Views)
Hello again
Yes that sequence file is working for me. That's werid tho...
(1,709 Views)
Seems like the output comes with a space at the end
If I change the condition to the word being 5 characters, it seems to be working.
What would be the easiest way of getting rid of the space characteR?
Thank you in advance !
(1,707 Views)
You can remove the last character of a string variable with this expression:
Locals.MyVariable=Left(Locals.MyVariable,Len(Locals.MyVariable)-1)
(1,704 Views)
