NI TestStand
If-Then Expression question
I have a need to branch on a parameter pulled out of a larger VI...
Given the following partial list of VI call parameters
+ Error In
Pass/Fail?
Report Text
- HB Actual
   WBL Zone B PL   Number(U8)   Out   (Checked)
   WBL Zone A PL   Number(U8)   Out   (Checked)
I tried
Step.Result.HB Actual.WBL Zone B PL >0
as my conditional expression...
Got Report
Unexpected token Actual:
Tried Step.Result."HB Actual"."WBL Zone B PL" >0
That just moved the error to the . after Result..... sigh...
Help?
(4,003 Views)
Accepted by topic author Everseeker
Hi Pat,
It seems as if you are trying to reference the VI parameter names in the TestStand Step.Results, is this correct? I wouldn't have expected to see these in Step.Results unless you had created a custom step type.
What have you entered in the values field for these VI parameters?
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(3,956 Views)
@CharlieRodway wrote:
"... What have you entered in the values field for these VI parameters?..."
 Ahhhh... THAT little question solved my problem
Stuck local variables there and can now query them as needed... Thanks!
(3,949 Views)
No problem - that was going to be my next suggestion, but I wanted to make sure I understood what you were doing!
Glad I could help,
(3,946 Views)
