NI TestStand
Image in Pdf report using Wkhtmltopdf converter
I have an issue regarding the conversion of an HTML report to Pdf using Wkhtmltopdf generator that is already explained at Test Stand Model Plug-in: Printing Reports and Generating PDF Reports - NI Community.
I want to add a picture to the pdf report after it generates.
How can I achieve this or is there any other alternative ?
Thanks in advance
(1,506 Views)
Do you have the image data available while the sequence runs?  It would be easier to append the image data to a Step.Result.ReportText while the test is running; this will then allow the image to be included in the HTML report and thus included in the generated PDF report.
(1,427 Views)
