NI TestStand
Import Access DB to SQL Server
I'm trying to setup a SQL-Server Database.
Currently i'm using Access, and my own Scheme which is very close to the "Generic Recordset".
I've tried several things.
* Strip my .mdb to contain only tables but no data.
* Import this to SQL Server.
** Import complete .mdb database including data.
My tablenames in SQL Server always gets the prefix "dbo". That means they are using a "dbo" scheme - right ?
I can export my Scheme (.ini) from TestStand, but how do I get that into SQL-SERVER ?
Currently I get the error below:  (is this the result of not having the correct scheme in place ?)
An error occurred calling 'LogMultipleResults' in 'ITSDBLog' of 'zNI TestStand Database Logging'
An error occurred executing a statement.
Statement: UUT_RESULT.
Description: Cannot insert the value NULL into column 'ID', table 'PTA_DR2_COMMON.dbo.UUT_RESULT'; column does not allow nulls. INSERT fails.
Number: -2147217873
NativeError: 515
SQLState: 23000
Reported by: Microsoft SQL Server Native Client 11.0Description: The statement has been terminated.
Number: -2147217873
NativeError: 3621
SQLState: 01000
Reported by: Microsoft SQL Server Native Client 11.0Description: Multiple-step OLE DB operation generated errors. Check each OLE DB status value, if available. No work was done.
Number: -2147217887
NativeError: 0
SQLState: 01000
Under the "data link property" in TestStand I set up to use a "Specific User Name and Password" which is set up in SQL Server.
I choose to save the "Password".
Test connection is OK.
If I close the window, but reopen it right after,  the password properties are gone... that means it's not saved !   Why ?
If I use NT integrated Security, the access to the database is working.
(3,529 Views)
Accepted by topic author NikolajEgeskovOstergaard
I found a "Solution" by exporting each table one by one from Access instead of Importing on SQL Server.
Now it seems to be OK
(3,487 Views)
