NI TestStand
Import/Export properties
I have a sequence of 300+ steps.  I've made it so that I can reuse the same function for each step so I have copied and pasted the same step 300 times.  Now I need to simply give each step a unique name so I can import and export the properties that I need.  Is there any way to give each step a unique name without clicking on each one to change it??  It seems you can't import the step name, what a pain.
(2,926 Views)
rreis,
If you want your step names to be unique you can do the following:
1. Go to Configure->Sequence Editor Options->General
2. Verify that the 'Make Step Names Unique when Inserting Steps' box is checked.
3. Now every time you copy and paste a step it will be assigned a unique name.
If you already have a sequence with duplicate step names you could write a sequence that programmatically changes the step names so they are unique.
Hope it helps
(2,917 Views)
