NI TestStand
Import data from a spreadsheet (data file) into TestStand steps
I have some 100+ customers with different configuration data.  Whenever I need to run test for a different customer, I need to update the TestStand steps in each sequence file with new values.
I'm thinking if there's a better way to simplify this, perhaps by using a spreadsheet/data file to input the data?  But I have no idea how to do this?
My steps are from two sources, one type is a dotNET DLL, another type is Active X/COM (calls TestComplete software).
Any suggestion would be appreciated!
Thanks!
ph2
(3,314 Views)
Yes there is, make use of the PropertyLoader. Checkout the examples found in the TestStand Examples folder.
Regards
Ray Farmer
(3,313 Views)
You can also use the Write() and ReadEx() methods to create PropertyObject files from variables and read those in at run-time.
CTA, CLA, MTFBWY
(3,310 Views)
Thank you both! I'll look into the solutions.
(3,300 Views)
