NI TestStand
Import excel file with property loader
I have an excel file. Can someone explain a way how I can load it using Property Loader. I will need the appropriate values of Resistance and Current (in the same row as Frequency)for each Frequency.
Thank you
(1,902 Views)
Usually you use the Import/Export tool to export your data to excel.  Then edit it.  Then you can use the property loader step to read it back in.  There are other things the file needs besides the header names.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019RPoSAM&l=en-US
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,844 Views)
