NI TestStand
Importing SharePoint .xlsx file vs desktop .xlsx
I have encountered a problem when importing properties from a .xlsx file. The original file was created in desktop version of Excel and was working fine, then I uploaded that file to SharePoint and tested it by downloading the file from it and importing the properties. Once again everything was working fine. However once I edited any line of the .xlsx file in the SharePoint website and tried downloading and importing the file, TestStand started throwing this error: Found empty cell values. Make sure there are no empty cell values and retry operation. The reported error line was not even modified and has not changed between desktop and sharepoint excel file versions. I reverted all changes in Sharepoint excel file, however the error still occured.
I checked with file diff the differences, and the content was identical. However the downloaded sharepoint file was 5 kB bigger. Does anyone have any ideas as to what the problem could actually be? Thank You in advance.
Message 1 of 1
(1,096 Views)
