NI TestStand
Impossible de changer de version teststand
Bonjour
Hello
I have a machine on Windows 10 with Teststand 2013
I installed Teststand 3.1 everything worked fine
Then when I want to go back to Teststand 2013 it doesn't work anymore
Teststand selector  version when I ask to activate the 2013 version
Teststand freeze uninstalls too
I don't know what to do to restart teststand
Thank you
Michael
(1,553 Views)
Hi Lunik,
In my experience, I've found that you need to install multiple versions of TestStand in release order. If you do them out of order, I've seen issues like you describe. I believe (but don't guarantee) you'll have better luck if you uninstall both versions, then reinstall 3.1 and then 2013 in that order.
Also, I'm pretty sure that 3.1 is not supported on Win10, so that might also be a factor in what's causing your issues.
Hope this helps.
-Jack
(1,530 Views)
I use CCLEANER  before unistall TestStand 3.1 and 2013
I do this 3 times because sometime the unistall operation stop before the end.
(1,466 Views)
