NI TestStand
In TestStand, How do I pass variables to a sequence, other than the standard Input Buffer?
I have Labview VIs that have arrays as inputs, I want to pass information in that array to the VI. TestStand already has the Input Buffer setup, but how do I create more input buffers, like array input buffers?? I know that the "Parameters" section in the sequence file is for passing info to subsequences, but that does not help me, Thank you in advance!!
(3,661 Views)
See the TestStand shipping example located in the directory \Examples\AccessingArrays\UsingLabVIEW. This will show you how to pass arrays back and forth from a VI to a sequence variable.
If you are trying to create a step that handles arrays, then you will need to create a new step type that has an array step property. There is an example on the NI web site of a step type that handles arrays. Go to www.ni.com/support and search the Examples Program database using the search string of:
+"step type" +waveform +teststand
(3,661 Views)
