NI TestStand
In simple user Interface modify the sequence view to show only executing step
I want to see only the Single executing step  in sequence view of the user interface
are there any egs for the same!!
(4,442 Views)
This is relatively trivial to implement yourself. Handle the UIMessageEvent of the ApplicationMgr and when you get a trace UIMessage do something like the following:
if (uiMsg.Event == UIMsg_Trace)
    int notUsed;
    String currentStepName = "";
    SequenceContext context = uiMsg.Thread.GetSequenceContext(0, out notUsed);
    if (context.NextStepIndex >= 0)
        currentStepName = context.NextStep.Name;
    /// Do something with currentStepName like update an indicator control.
Hope this helps,
-Doug
(4,431 Views)
thanks Doug
i will try that
(4,426 Views)
