NI TestStand
Incorrect character in XML report
Hi all,
Sorry for all these posts, but another issue arrived.
At the end of sequence execution, SeqEdit displays an eror message instead of displaying real report :
Unable to load the XML Report. At line 510 Un caractère incorrect a été trouvé dans un contenu de texte.
I opened XML file with a text editor  and at line 510, I get :
<tr:TestResult ID = "tr-7fd65b92-b057-11e8-b3d3-005056c00008" name = "ÍM˜w%">
I don't understand the root cause of this bad characters in the "name" item.
Doesn't it be a known issue?
Thanks in advance for your help.
(2,969 Views)
Please, I need some help. I have searched but don't find the root cause.
TestResult name contains non ascii characters, example : �M�wj&gt;�����T�w��w�x�x
Hexadecimal dump of this name is : CD 4D 98 77 6A 26 67 74 3B C0 08 FE FF FF FF 54 E4 93 77 B2 E1 93 77 D4 0F 78 1A
How can I investigate on this issue?
Thanks for your help.
(2,940 Views)
Did you make any changes to the shipping ATML report generator installed by TestStand?
Anand Jain
(2,934 Views)
I didn't make any change. XSL file date is 15/11/2017.
(2,932 Views)
