NI TestStand
Incorrect path to CVI.exe
I'm fairly new to TestStand, so maybe I'm missing a simple configuration setting.
When I try to edit CVI code from a TestStand sequence I get this error message.
The correct path is C:\Program Files (x86)\National Instruments\CVI2012 .....
CVI does open file after the clicking OK.
The problem occurs when I try to debug a code module in an extenal instance of CVI.
It's causiing TestStand to hang.
Any ideas?
Curt
(4,418 Views)
Hi Curt,
This looks to me like a bug. Do you have similar issues with any other adapters? I might try repairing your TestStand installation just in case it is a bug in the installation itself.
Steven Gloor
Staff Customer Engineer - CTA, CLD
(4,375 Views)
