NI TestStand
Incorrect regional keyboard localisation ( " and @ swapped) in TestStand 2010SP1
Numpty question here....
3 of us are using TestStand 2010 SP1.
2 of us have issues with regional keyboard mapping being wrong - that is the " and @ keys are swapped - but this appears only to be within TestStand.
The other user's keyboard mapping is fine.
We all have the same keyboards (English - UK).
We all have the same settings under Configure > Station Options > Localization   (Language set to English).
All other Windows apps work fine on our PCs (Office 2010 etc).
So where is TestStand picking up its regional localisation and how do we fix it!
Many thanks
Alan
(4,296 Views)
What settings have you got in the StationOptions under the Localization tab?
Regards
Ray Farmer
(4,289 Views)
As mentioned in my first message, we all have the same settings under Configure > Station Options > Localization   (Language set to English).
The 2 tick boxes are not ticked. (Use localized Decimal Point and Recognize Mulit-byte Characters)
Alan
(4,285 Views)
Is there any difference in the Windows OS regional settings on the machine on which it works vs. the one it doesn't? If so which settings?
-Doug
(4,274 Views)
Windows regional settings are identical between working and an non-working PC.
Any other ideas?
(4,254 Views)
Accepted by topic author AlanKnowler
Hi Alan,
Thank you for your forum post. It seems another TestStand user has experienced a similar issue in 2010 SP1 whereby his keyboard defaulted to the US layout when he was using the DE (i.e. German) layout.
The issue was solved in the forum post here.
It looks like this is unexpected behavior that is a side effect of new functionality added in TestStand 2010 SP1. R&D has been informed. To work around this issue in the meantime, you can execute a Statement step in "TestStand 2010 SP1" that contains the following expression:
RunState.Engine.ConfigFile.Data.SetValUnsignedInte​ger64("ExpressionEditOptions.AutoLanguageOptions", 1, 0x2ui64),
RunState.Engine.ConfigFile.IncChangeCount(),
RunState.Engine.ConfigFile.SaveFileIfModified(fals​e)
Hopefully this assists with your Keyboard issue Alan, please keep me informed with your progress.
Many Thanks
Jamie S.
(4,243 Views)
Works for me. Thank you.
(4,210 Views)
