NI TestStand
Index array
I have an array and I want to point to a certain element in the array using its index. Basically I need to use the labview equivalent of "Array Index" in teststand. If im not wrong, GetNthSubProperty does the same thing? But I am looking for an example to use it. I keep getting errors when I try to use it. Here is my example:
MyArray : [0..5]
I am trying to point to index [4] of the array.
(6,217 Views)
Accepted by topic author A2saSandel
Locals.MyArray[4]  should work.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(6,201 Views)
Thank you so much!
(6,167 Views)
