NI TestStand
Insert Link in xml file
how can I insert a link into a xml file?
Some of my tests create a very long log-file and I don't want to display the whole file in my report. So I decided to insert a link in my report. But I don't know how to do this.
Thanks for your help
Daniel
(3,291 Views)
Daniel,
it is not possible to create such links automatically by choosing a setup. but since the report itself is created by a sequence and the usage of dll's, you can modify the method of creation in a way that links will be possible. but i have to warn you because this is very extensive and if you dont do it carefully, you can crash your whole report-generation. (copy the sequence and dlls from NI-folder to user-folder!).
One point to shorten the report can be the usage of "new UUT report-file for each UUT" in the report-options.
Norbert B.
NI - Germany
Norbert
Expert: Geometry
(3,283 Views)
Also, with the XML file format, you can modify the Style Sheet so that when it is displayed in a browser, it appears differently.
Allen P.
NI
(3,271 Views)
