NI TestStand
Insert a comment in Teststand Report
I'd like to insert in HTML report of Teststand 4 the same comment that I wrote in Pass/Fail Test Properties. I've already used
Parameters.Result.ReportText,
but in this way I have to write the comment twice. Does exist some class or similar to get the comment that I wrote in the Test properties?
I tried to modify the Teststand HMTM report sequence, but without success.
Do anyone some ideas to do that?
Marco
Message 1 of 18
(5,695 Views)
All you have top do is in the Post Expression of the Step Properties is pass that ReportText value to the Parameters.Result.ReportText.
eg
Parameters.Result.ReportText = Step.Result.ReportText.
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 18
(5,690 Views)
Ok, but I'd like to reuse the comment that I've already written in Comment section. Is it possible to recover the Comment without rewrite it in a post condition?
Message 3 of 18
(5,682 Views)
Forgive me but I may be missing something here!
You have a comment in Step.Result.ReportText and you what it to appear some where else via Parameters.Result.ReportText or maybe you want it at a different location and not bothed about it being in the Step results. It which case instead of specify the Step.Result.ReportText then write it direct to Parameters.Result.ReportText.
But if you do want it both places then you are going to have to perform some extra task. That extra task could be performing the Post Expression or create  a custom step type that already does that Post expression built in.
Regards
Ray Farmer
Regards
Ray Farmer
Message 4 of 18
(5,667 Views)
Corma,
If you are trying to put the comment of the step into your report, you can access the comment through the TestStand API, if you are using TestStand 4.0 or later, you can do this with the following expression:
Step.Result.ReportText = Step.AsPropertyObject.Comment
Josh W.
Certified TestStand Architect
Formerly blue
Message 5 of 18
(5,663 Views)
Coma,
Maybe you can post a small example showing what you are trying to achive.
Regards
Ray Farmer
Regards
Ray Farmer
Message 6 of 18
(5,662 Views)
First of all, thanks to all...now I try to explain what I want to to.
1. In TestStand 4, in the Main Sequence, I insert a Pass/fail test.
2. In the Module Panel of Pass/fail test I link the dll and the test that I wrote in CVI
3. In Properties Panel of Pass/Fail test (in General Option) I insert a comment in the Comment Box
This is the scenario.
Now, I execute a Single Pass, and TestStand gives me a report in HTML format. I'd like that near the Step Name, appears also the comment that I wrote previously in Comment Box.
Best regard
Corma
Message 7 of 18
(5,654 Views)
Hi Corma,
You can access and change the comment of a step programmatically using his PropertyObjectReference.
Namely in TS 4 the post-expression
Locals.ClonedComment = Step.AsPropertyObject.Comment
copies the comment of the actual step ( post-expression ) to a local variable named ClonedComment.
My message is use "Step.AsPropertyObject.Comment" and you should be able to programmatically control the Step comment as you prefer.
Best Regards
FiloP
It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong.
Richard P. Feynman
Message 8 of 18
(5,624 Views)
Sorry I didn't see before.
I actually expressed with my word Josh's message.
Best Regards
FiloP
Richard P. Feynman
Message 9 of 18
(5,622 Views)
Ok, but in which way I can recall the local variables (Locals.ClonedComment) used in your file, in reportgen_html.seq ?
If I start a single pass, the comment is not displayed....sorry, but I used TS4 only from 2 week, and i'm not very skilled.... 😞
Message 10 of 18
(5,614 Views)
