NI TestStand
Insert a specified built-in or custom step type in Teststand using CVI
  I try to build a step type . this step type specifies an adapter of DLL, which is developed under CVI. I want to use Teststand API functions in CVI to fulfill the following functions.
  1, insert a specified built-in or custom step type into current sequence;
  2, insert a specified built-in or custom step type into another sequence.
Thanks!
Jacky
(2,806 Views)
Hi Jacky,
There is an example program called Programmatically Inserting a Step into a TestStand Sequence Using LabWindows/CVI and a KnowledgeBase called Programmatically Inserting a New Step in the Currently Executing Sequence that should answer your question.
Hope this helps!
Best Regards,
Jonathan N.
(2,791 Views)
