NI TestStand
Insert element into array (manually)
I have an issue with the insertion of elements into an array. Here's the situation;
- I've declared an array of strings as a local variable (let's say a 10-element array)
- All the fields of the array have been filled with strings.
- I would like to insert a new element into the array (for example at index 3)
When I go to the "bounds" property and increase the array's bounds, the new element is added at the end of the array. Is there a means to insert the new element in any other position ?
Zouz
(3,695 Views)
If you call a PropertyObject.SetVal<DataType>ByOffset() method, you can pass PropOption_InsertElement to the options parameter.
(3,689 Views)
