NI TestStand
Inserting Image/Logo
Hi
How do I insert a image in to top right of the report in test stand (opposite to STATION ID, SERIAL NUMBER ect..). See attached word file for exact location.
OR
Top of the Report?
(3,974 Views)
Have you looked at this example
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E28156A4E034080020E74861&p_node=DZ52224&p_source=external
Also, there is a tutorial in the Getting Started Manual.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,974 Views)
I did try, but doesn't work.
(3,974 Views)
what version of teststand are you using?
regards
Ray Farmer
Regards
Ray Farmer
(3,974 Views)
Hello
THANK YOU FOR YOUR HELP.
I am using Version 3.0
It�s working now. The reason it wasn't working, on the report option "On the fly report option" was selected. But the logo appears on top of the page, how do I display opposite to STATION ID?
(3,974 Views)
Try this example.
In the ModifyReportHeader. In the Expression step, I use a Find() to get a start index after the string "Sttion ID:"
Then I use the SearchAndReplace() to change "\n" for the string contained in Locals.AddToHeader, but I only do this once. Hence the value 1 after the False parameter.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,974 Views)
