NI TestStand
Install ATML Toolkit 2010 after ATML Toolkit 1.0
I'm trying to install ATML Toolkit 2010 (evaluation) on my WinXP system with TestStand 4.2.1.
I already have the former ATML Toolkit 1.0 installed and working.
Now the ATML Toolkit 2010 installer asks me to uninstall that previous version and exits.
I don't seem to find any uninstallers for ATML Toolkit 1.0 on my system (neither a start menu shortcut, nor any executable for it under Program Files).
I checked the readme files for both the older and the newer ATML Toolkits, and couldn't find info on removing the 1.0 version.
Actually, I need the new evaluation version just to check compatibility, so I'll have to be able to return to the older version for while. Because of this, I'm also curious how will I be able to remove the 2010 version as well.
Thanks, BB
(3,239 Views)
Accepted by topic author bblaze
Have you tried in the Control Panel - Add, Remove Program then under National Instruments Software
Regards
Ray Farmer
(3,237 Views)
Yep, trivial, indeed. Without much NI experience, I didn't recognize that 'National Instruments Software' entry (2.96MB) as the generic component update/remove mechanism.
Thanks.
BB
(3,234 Views)
