NI TestStand
Install ATML Toolkit 2010
I've been trying to install the TestStand ATML Toolkit 2010 for evaluation, everything seems to work fine with the install process but when I try launching the tool using 'Tools' > 'Configure ATML TD Translator' I keep on getting the error below. I tried uninstalling, restarting and reinstalling but that didn't help
Anyone seen this before?
Thanks for your help!
<<- N ->>
(3,162 Views)
Hi
You should be able to resolve this issue by coping the ATMLTDTranslatorConfig.xml from the default cfg folder (Win 7 - C:\ProgramData\National Instruments\<TestStand>\Cfg to your customized cfg folder at c:\TekCal-NI\Config\TestStand\Cfg\ folder.
Regards
Anand Jain
(3,160 Views)
Thanks! That did it. I tried to find the file on Windows but apparently it didin't look in that directory (C:\ProgramData)
<<- N ->>
(3,152 Views)
