NI TestStand
Install StepTypes into TestStand with an installer
Hello, i need to install some steptypes into teststand on another machine with an installer. Im writing the script using inno setup and i will siply install my steptypes in the StepType folder of the TestStannd program.
Do i have to do anything with the ini file or something else? Just wondering, thanks
(751 Views)
If your steps are using any code modules for Pre-/Post-/Edit-Steps, you will need to coopy them over as well.
Are you copying to %TestStand% or %TestStandPublic% ?
(727 Views)
