NI TestStand
Install Teststand 2021 on any other drive than C
During normal software installation, Teststand 2021 installer is not asking anymore operator to select installation path, where I could have selected software installation drive and folder and is performing install on default system drive.
Looking into a way to install software from offline installer on drive D:\ of my PC it was suggested to try using a procedure described as "Automating an installer - NI", by running command "start /wait Install.exe --passive --accept-eulas --prevent-reboot".
Using this method, installation was also made on folder "C:\Program Files (x86)\National Instruments\TestStand 2021", however for me is not OK as system drive  has no space to support install of operating system together with other NI software package (like Labview 2021, NI-VISA, NI-DAQmx, NI-ICP, NI-GPIB etc).
Your answer regarding how to install Teststand 2021 on drive D:\  will by much appreciated !
Thank you
(1,122 Views)
I suggest reposting this on the NIPM Forum, since the installation is managed by NI Package Manager. Having said this, IIRC it is not possible
(1,048 Views)
