NI TestStand
Instrument identification in process model
Hi All,
I have a set of Instrument using LXI,VXI,PXI,MXI and GPIB buses. I have the code module in Labview to indentify and initialize the instruments. I need to identify the instuments every time the Test sequence is loaded,hence i'm thinking to modify the process model to do the same.
But i don have any idea,where to integrate my code module in process model. I require some suggestions for the same.
Thanks in advance
Regards
VDC
(3,606 Views)
Hi VDC,
it is possible to use the process model. But i you wrote you want to initialize everytime you load the seqence file. There is a Engine Callback: SequenceFileLoad. This sequence is called every time you load the sequence. You will find it under Edit->Sequence File Callback..
Greetings and Merry Christmas
from the lake of Constance, Germany
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,592 Views)
Hi  j_dodek  ,
Thanks alot for reply. But as Engine Callbacks are called everytime the step to test the UUT e xecuted. But i wan't to initialize the Instrument only once when the Test sequence is loaded.
Merry Christmas
VDC
(3,583 Views)
Hi  j_dodek,
In addition to what i have commented in the last message,can't i call the Instrument Initialization utility in the "PreUUTLoop" Model callback. Its gets executed everytime a new UUT is tested, and hence the overhead to execute after each step is saved,as in engine Callback.
Regards
VDC
(3,579 Views)
You need to read up a little on callbacks. All callbacks are not called every time. The sequence load callback is only called when the sequence is first loaded.
(3,574 Views)
Hi VDC,
I have tried the mentioned Callbacks. All workes as assumed. I figured out that SequenceFile callback ist probably not the best for you because you can not give the instrument handel to your running execution(uut) with a SequenceFile Global (OK there are other solutions but i think they are too deep or not effectiv.)
I think you should try Pre and Post(for Cleanup Handles) UUT Loop
Just try the TS4.0 example
Greetings
Juergen
--Signature--
(3,570 Views)
