NI TestStand
Integrating MKS with Teststand
I am using Teststand v2.0 under windows 2000 and wish to integrate with MKS source control. Under "station options" it does show MKS as the default source control provider but all the options in the "source control" menu are greyed out
(3,117 Views)
Hi ScottChristie,
Thanks for contacting National Instruments! TestStand 2.0 will integrate with any source code control system that conforms to the Microsoft SCC interface, including MKS. You will need to use a TestStand workspace in order to use the source-code control features. You can read more about this here:
Knowledge Base 2VG8G1Y6: Problems Working with TestStand and Source Code Control Software
Let me know if you have anymore questions!
David Mc.
National Instruments - Applications Engineering
(3,117 Views)
