NI TestStand
Interfacing HP Quality Center with Teststand / LabVIEW
Hi All,
Can we interface HP Quality Center with NI Teststand or LabVIEW?
Regards
Raviteja
Message 1 of 9
(5,688 Views)
The short answer is yes. The means to do this would be via Windows' interfaces of ActiveX or COM. You can think of LabVIEW or TestStand as anything external that needs to speak useing ActiveX/COM.
That's not a specific responce and leaves a bit of work with no example (sorry). Hopefully someone knows of something like an example. But you won't be violating any laws of the universe trying to do something imposible.
Good Luck!
Charlie M. CLD
Message 2 of 9
(5,407 Views)
Hi Charlie,
Thank you very much for your reply 🙂
Regards
Raviteja
Message 3 of 9
(5,398 Views)
Hi Raviteja,
Are you able to integrate HP-QC in LabVIEW/TestStand
Message 4 of 9
(4,797 Views)
@Raviteja wrote:
Hi All,
Hope using in LabVIEW is pretty easy.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 5 of 9
(4,794 Views)
In LabVIEW how can we interface?
Message 6 of 9
(4,792 Views)
First HPQC is installed in system
Then you can access using Active X Controls (based on the Methods available you can use)
Message 7 of 9
(4,789 Views)
Thanks PalanivelT 🙂
Will try it out.
Message 8 of 9
(4,787 Views)
Palanivel Thiruvenkadam,
Did you ever get this working?  I know it's not good to post to very old threads but I've not seen anything newer on the topic.
If you have I'd really appreciate if you can share what you have or anything you've learned as I need to do the same thing.
Dave Stodola
Message 9 of 9
(3,146 Views)
