NI TestStand
Intermittent Runtime error - pure virtual function call
I have an intermittent runtime error - pure virtual function call & don't know what cause it? Since It only occurs & crashes once awhile therefore it's difficult to trap it for debugging.I suspect it come from TestStand ActiveX API which I use in my User Interface Application project but I'm not really sure.
Does anyone experience this kind of problem when working with TestStand API ? If so any
suggestion? I have noticed in the TestStand API header file teapi.tlh contain many raw_.... function defined as pure virtual function. What are these raw_... function ? I don't think I use any of these function in my project.
Many thanks!
(3,372 Views)
Danh,
I don't believe that your problem can be solved with the information you have provided unless someone else has experienced the same symtpoms which coincidentally have the same cause as in your case.
Is there any other information you can provide that can help localize the problem?
1) What is happening when the error occurs?
2) Does the error always occur in the same place?
3) Does it always occur with use of certain resources (e.g. DAQ, GPIB, VISA, printer)?
4) Does it occur when using the sequence editor?
5) Does it occur when using one of the shipping operator interfaces?
6) Does it occur only when using your operator interfaces?
7)Is it related to a specific sequence or any sequence?
😎 Does it happen when you executed your sequence with/without a process model entr
y point (i.e. Execute>>Test UUTs, Execute>>Singal Pass or Execute>>Run MainSequence)?
9) How often does it happen?
10) What version of TestStand are you using?
11) With what language (include versions) are you programming your code modules?
12) With what language (include versions) are you programming your operator interface?
13) Is there any error code reported with this error message?
14) Is this error reported in a TS run-time error dialog or is it reported directly 1by the operating system?
15) Have you searched the web for related errors? For example, the following link describes a particular programming mistake that can lead to this error
http://support.microsoft.com/support/kb/articles/Q125/7/49.asp
By investigating answers to the above questions you may be able to narrow the cause of this error, which might allow you or others to help solve the problem.
(3,372 Views)
