NI TestStand
Internet Explorer Warning Message
When I use an external viewer (Internet Explorer) to view the generated TestStand xml report files, I receive the following dialog from Internet Explorer:
Scripts are usually safe. Do you want to allow scripts to run?
I tried setting the Internet Explorer security settings to Low and I still get the dialog. Is there any way to suppress it? BTW, I am running IE 6.0.
John
(3,094 Views)
Hi John,
I've found a Knowledge Base that may be related to your question. Try following the instructions in the following link.
http://digital.ni.com/public.nsf/websearch/7A0FD2C1FCE0327D86256FF600652B01?OpenDocument
Hope this helps, have a good one John!
Message Edited by DWeiland on 05-23-2006 06:04 PM
Dan Weiland
(3,070 Views)
