NI TestStand
Interpreting a Post-Expression step
I am fairly new to Teststand.  How do I interpret this post expression.  There is a custom data type that has been created.  I understand the part till the "False" after "Evaluate(Step.DataSource):False.   However, I am not sure if the step after the following comma containing a string comparison is the beginning of an else if.  Please provide assistance in referring me to some documentation to understand this step.
Step
.DataSource !="Step.Result.String"? Step.Result.String = Evaluate(Step.DataSource):False,(StrComp(Step.Result.String, Step.Limits.String,(Step.Comp =="CaseSensitive"?0:1))==0)?"Passed":"Failed"
(3,267 Views)
Accepted by topic author kerugoya
There are two statements.  The first is a way to assign Step.Result.String to the value of the data source if it isn't used for evaluation.  The comma starts a new statement, which evaluates the step result based on whether the Step.Result.String is equal to Step.Limits.String.
The ? : syntax refers to a conditional, in the following way- (Condition)?(True case):(False case).
(3,266 Views)
