NI TestStand
Invalid Step Type using ASAM XiL Steps
I'm currently using an evaluation license of Teststand 2017 SP1, to see if i could use it to connect to my HiL-Testbench via XiL-API. I also installed the XiL-API step package. I used one of the XiL-API examples coming with Teststand wich returns a run-time error.
I already googled it, but can't find any solution. Does anyone know where this error is coming from ?
Thank you
Stephan
(2,716 Views)
Hi Stephan,
do you by any chance run this example by Operator Interface instead of Sequence editor? This could be potentially the reason.
Patrik
CTA, CLA
Helping (sharing) is caring!
If the post was helpful - Kudo it.
If the post answered your question - Mark it as Solution.
(2,659 Views)
I'm getting the exact same error, definitely running from the Sequence Editor and not the OI.
(2,470 Views)
