NI TestStand
Is Teststand able to install and implement on Linux system
I was using Testsand on windows before,
Just want to know that if NI Teststand able to install and implement on Linux/Unix system?
(6,616 Views)
Accepted by topic author liuqing
Since TestStand is an ActiveX Server and i am not aware of any well written ActiveX wrappers for Linux, i doubt that it will work.
Officially, TestStand is only supported for Windows. So if you achieve by any what-so-ever-open-source-code to install and run TestStand on Linux, you wont get any support from NI if anything unexpected happens.
Norbert
Norbert
Expert: Geometry
(6,605 Views)
Thanks Norbert~
(6,480 Views)
Has the advent of .NET Core on Linux changed anything in this respect?
Like, re-implementing TestStand based on .NET Core or using a COM infrastructure which may possibly lie underneath .NET Core on Linux (although this https://docs.microsoft.com/en-us/dotnet/standard/native-interop/cominterop points into the direction that COM is only supported in .NET Core on Windows).
(3,175 Views)
