NI TestStand
Is it possible to Dynamically or on the fly change path of the datalog or stdf to be saved
Hi Team,
I was trying to change the path of the datalog or stdf of my test program. I would like to know is there any option to change the path dynamically while running the test program because I need to save those file in each dut folder which Iam creating with Device number on the fly or while running the code.
Please help me on this.please let me know is there any option in Teststand to do the same.using version 20 bundle.
Arjun
(542 Views)
Sounds like you are using the semi-conductor module... haven't worked with this one up to now.
In standard reports, you can have dynamic fiel paths and names
(511 Views)
