NI TestStand
Is it possible to generate one report with parallelmodaldiff, with all steps of the modals?
I want to use TestStand for an automatik Softwaretest, so I have different states and want to now in which state my test is failed.
Is it possible to generate one report with all steps?
(2,897 Views)
The Parallel Process Model contains Execution Entry Points that create reports for all steps of all UUTs that have results to log by default. The Parallel Process Model's decription and management of report generation is covered in detail in Chapters 14 and 15 of the TestStand 2.0.1 User Manual found at the following link:
http://digital.ni.com/manuals.nsf/websearch/50B69DA356B8D38C86256A0000660E6B?OpenDocument&node=132090_US
Jason F.
www.ni.com/ask
(2,897 Views)
