NI TestStand
Is it possible to select teststand station model programatically?
I have a lot of TS projects within a workspace that use different process/station models (parallel, batch and sequential...)
How can I select proces model within for example when test-sequence is run?
(2,546 Views)
Hello AndrazS,
I've seen in a recent post of Joel_V, the use of SequenceFileOpen callback to change the current Process Model file (see test.seq). But that's not the way I'll prefer.
If you know which ProcessModel is expected for a giver sequence file, I'll set it in Sequence File Properties :
(2,499 Views)
