NI TestStand
Is there a Flag indicate if the seq is called from other one or run independ
Is there a Flag that indicate if the seq I am running is called from other seq. or it is running independently?
(3,054 Views)
Hi FMB,
There is not really a flag but there is a property call RunState.CallStackDepth you can check.
If this is greater than 0 then there is a caller sequence. Therefore to find the name of the caller sequence you would use NameOf("RunState.Caller.RunState.Sequence").
For every increment in value of the CallStackDepth you would add "RunState.Caller." to the beginning of the lookup string.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,054 Views)
Thanks Ray... this is exactly what I need.
(3,054 Views)
