NI TestStand
Is there a way to add VS merge modules to a TestStand deployment
I have a DLL I am going to install in the GAC. It is in a merge module (msm file). Can I get the Test Stand Deployment utility to pull it in and install it as part of its installer build?
(2,771 Views)
I'm not sure if you could get the deployment utility itself to pull it in, but you could definitely modify the MSI file created by the deployment utility. The following tutorial is for CVI, but it lists ways of modifying an MSI file that you can probably use with the TestStand installer.
http://zone.ni.com/devzone/conceptd.nsf/webmain/2FF2B17F4DC7CFDF86256AA3006990C4?opendocument
Ryan K.
(2,771 Views)
