NI TestStand
Is there a way to center the text on a message popup
Looking for a way to center multiple lines of text on a Message Popup.
(4,599 Views)
sdrochek3 -
The step type does not export any option to center text that it displays. If centering text is a requirement, you will need to create a custom dialog in your ADE of choice and display that instead.
Scott Richardson
https://testeract.com
(4,578 Views)
