NI TestStand
Is there a way to configure TestStand on a system with only base deployment?
Been told there is a app I can download to configure stuff like reports, adaptors and variables etc on a system which only has the Base Deployment license (Basically, a system on which the TestStand Development system has not been installed)
Anyone know if this exists and where I could find it?
Many Thanks
(2,871 Views)
Morngoose,
You can use the User Interface to do that.  That's the whole purpose of the UI.  How do they execute your sequence on the deployment PC if they aren't using the UI?
I believe you have to log in to the UI as an admin though.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,870 Views)
