You can select Tools->Sequence File Documentation from the Sequence Editor menu. This will produce a report in HTLM or text that describes each of the steps in the setup, main, and cleanup sections of each sequence. It may be more information than you were expecting, but it is information you would need if you were to reproduce the sequence file from the documentation.
Mark Ireton
