NI TestStand
Is there a way to "comment out" a step in TestStand 3.5?
I want to temporarily mark a step to not execute. Is there an easy way to do this in TestStand 3.5. I don't want to delete the step and then add it back in when I'm finished debugging.
thanks,
Stephen
(5,080 Views)
You can skip the step.  Right click on it and go to Run Mode and then select Skip.
I am attaching an image.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,079 Views)
Thanks!
(5,074 Views)
No Problem-
Also, if you want to skip a whole bunch of steps you don't have to select them individually.  Just use Ctrl or Shift to select multiple steps and then right click with all steps selected and change the run mode to skip.
Regards and good luck,
jigg
CTA, CLA
testeract.com
(5,072 Views)
