NI TestStand
Is there a way to roll up steps in a sequence file
I have some pretty long sequece files that have many nested steps...Is there a way that I can "roll-up" these steps in my sequence?  I am having trouble keeping my "Ends" straight sometimes and I think it would be easier to see them rolled up and then expand the section I need to work on.
Anybody figured out a way to do this?
Matt
(3,257 Views)
I have no idea doing this but
what a about spliting your sequence file (i assume you have only the MainSequence in) into
a some subsequences and the MainSequence will call them.  So you can make a stucture like a book (MainSeqeunce)
with different chapters (Subsequnces)
hope this helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,244 Views)
You can expand the Setup, Main and Cleanup Groups but you can do it with a selection of Step.
The only way would be to group your steps into a Sequence and have your top level call a group of SequenceCalls.
Regards
RayF
Regards
Ray Farmer
(3,239 Views)
