NI TestStand
Is there a way to set an ActiveX reference to Nothing or test for "Nothing"-ness of an ActiveX reference?
In TestStand 2.0, is there a way to set an ActiveX reference to "Nothing"
(to use the Visual Basic term)? In other words, is there a way to release
the ActiveX DLL or EXE object without waiting for the ActiveX reference to
go out of scope?
Also, is there way to test whether or not a particular ActiveX reference has
been initialized (i.e. is or is not "Nothing")?
TIA,
Bob.
(3,444 Views)
Yes, there is an expression constant Nothing in the TestStand expression language. Just assign it to the variable or use it in an equality comparison. You can use a statement step to do this.
Doug Melamed
(3,444 Views)
D'oh! I didn't look under Constants and I couldn't find anything in the
user manual index...
Thanks.
Bob.
(3,444 Views)
Is there a way to do this from within a CVI DLL? I am setting a synchronization lock within TestStand, but I need to release the lock from within the DLL. I am storing the lock in TestStand as an ActiveX Reference.
Brian
(3,444 Views)
