NI TestStand
Is there an editor for the StationGlobals.ini file?
I have TestStand 3.0 and I am trying to edit the StationGlobals.ini file. It seems that I am unable to delete/add properties from within TestStand. Is there an editor or a correct way of editing this file?
Thanks in advance.
Martin Blandon
martin.blandon@gmail.com
(3,090 Views)
To linux_dude -
The StationGlobals.ini file is generated by the TestStand engine and its format is an object oriented format that represents the structure of the property objects in the globals. Hand editing the file will be problematic. The only way to edit the station global strucutre is to do it in the sequence editor.
Scott Richardson
https://testeract.com
(3,068 Views)
